Compressing design files in ABD has negative impact on dynamic views. I end up having to "Demote View" to be able to see alll the elements... Anyone has this problem?
Chris, make sure you don't have Dataset Accelerators enabled in your Compress options - compressing those will remove the resymbolization levels required by DVs. More information is available here:
http://communities.bentley.com/products/building/building_analysis___design/w/building_analysis_and_design__wiki/8252.compress-options-in-aecosim-building-designer-behaviour-and-configuration
