I have a problem with the grid template when trying to copy the template from the default in element templates it does not make the file in the correct part of the tree
I cannot then load the new template into the file from the settings in the grid template the v8 symbol is also greyed oyt in the templates dialog box which suggests something is wrong also
Very frustrating as I cannot edit any of the properties of the grid template which used to be very simple
C
Here is the method: Customising Grid Systems Symbology With Element Templates
Marc
Answer Verified By: Steve Cocchi
