How is it intended we use grab bars if they do not have a 2d representation?
Marc
Toilet accessories
The Grab Bars are only 3d
And the 42" is 36" (others are correct in length)
ONLY if your cut is above the grab bar which is not always the case. If you utilize the cut for things like toilets, and your plan needs to be cut below lets say 30" then these items don't show at all but a toilet does. I do as you mention in Elevation as everything is a 3d model without anything 2d. But I never take a elevation where it cuts thrugh a urinal - through the partitions yes but not the urinal. But a plan I many times cut at a different height and so like doors and windows and bath fixtures - the current workflow suggests we supply 2d in all 3d for a plan.
Answer Verified By: Steve Cocchi
