As part of a trial to provide QS with better information, I have finally installed the imodel plug-in for pdf and successfully created an i.pdf.. However it does not contain anything under the Items tab. On further investigation it would seem that the Item Browser within ABD has a problem. When Item Browser is called, ABD returns an error dialog "Failed loading tree definitions"
The Message Centre reports:
Are these two errors connected? and where should I be looking for the corrected configuration?
Crucially as no data is displayed in the Item Browser within ABD, there is also none in the pdf file. I need to get this resolved while the QS is still enthusiastic to learn new ways of QTOs!
Many thanks.
Patrick
