Why can't I enter in the "Elevation" field in the Floor Manager dialog. I'm pretty sure we use to be able to do this. How else would I be able to insert a floor elevation? For example, in the attached image I want the 4th floor to be below the "Cassette Roof" but all I'm allowed to enter is the floor to floor dimension. I'm sure I'm just missing something.
John K.
John, The Relative Elevation and the Elevation columns are derived from the 1st Floor Elevation and the Relative Elevation column will reflect the 'Use Relative Elevation' elevation when toggled on. In this case a renaming of 4th Floor and Roof-Cassette would be the process.
Hi John,
Please take a look at this method using GC: GC SS6 - Creating and Modifying ABD Floors and let us know if it would be practical in your case.
Marc
Marc,
I took a quick look at the process you suggested. Although this seems promising it does seem like it's a lot of work that Floor Manager should already take care of. I should be able to insert floors without having to rename everything above it. I would much rather specify the actual floor elevation and not the floor to floor dimension.
