Hi all,
I am new to Aecosim Building Designer and have just started trying to use the software in my day to day production. I have fumbled my way through setting up ABD on a network, and have a grasp of basic modelling. However I am now trying to generate some output which is where I am coming unstuck...
Would someone please be kind enought to explain the basics of the various files needed to get a typical drawing (say floor plan) on to a sheet. I am especially confused as to what a 'container' file is?
Thank you in advance.
Marc
In addition to what Marc suggests, Printing is "what you see is what you get". Once you get your view configured the way you want, just select Print with the desired output (paper, .pscript, .pdf, etc.) and that is what you should see in your output. There are also some more advanced features you can use to adjust or manipulate your output if you wish (pen tables, print styles, etc.).
Here are some links to training on the Bentley LEARN server. All of our QuickStart Live training sessions are free. And any courses the have On-Demand videos, the videos are free to watch. Each QuickStart Learning Path (Architectural, Mechanical, Structural) features a Creating Drawings session. Scroll down when you open the links to see the links to live-training sessions and videos.
QuickStart for Architects Creating Drawings
QuickStart for Mechanical Designers Creating Drawings
QuickStart for Structural Designers Creating Drawings
Here are more advanced sessions with videos for Architecture - the basics apply to all disciplines:
Architectural Documentation - Drawings
Here's a blog post on setting up title blocks per projects:
ABD Sheet Borders and Title Block Fields with Drawing Composition Tools and Detailing Styles
Hi Morgan,
The term 'container' is used fairly liberally to describe a file that 'contains' project information. With MicroStation's and AECOsimBD's ability to have multiple models inside a .dgn file, we think of the .dgn files as 'containers'. Sounds like you are on the right track with the way you have your file organized.
Some organizations/companies/users add another level of organization and create what could be called a 'Drawing Composition Master Model' or as I called it in my diagram 'Construction Drawing Master Model' (it is a container) that references the Discipline Master Model. And use that file to generate drawings. Just another level of organization.
I diagrammed this out, using mechanical and structural, keep in mind it depends on the project, size of the project, number of designers working on the project, etc. as to how to split it up. I call the initial files 'Working Models', this is where you do your modeling work. These are referenced to a 'Discipline Master Model', and the 'Discipline Master Model' is referenced to the 'Construction Drawing Master Model'. The drawings and sheets are generated from here. Keep in mind the drawing to sheet ratio is not necessarily one-to-one, think of large narrow projects where the plans may not fit on one sheet.
One thing this does is keeps the 'Discipline Master Models' pristine, in that they don't end up with all the saved views, markers, etc that are generated during the dynamic view process.
If I am working on HVAC, I can reference the structural 'Discipline Master Model', using Live Nesting and turning on the 'Ignore Attachment when Live Nesting' reference setting to keep the structural models from nesting up to the mechanical discipline master model.
Each discipline can organize the working models as needed - as Marc noted, architectural might have a core model, exterior model and floor-by-floor interior models, structural might have a foundation model, a primary framing model, a secondary framing model as it might not make sense for structural to go floor-by-floor.
Finally, I talk to a lot of our users who are small one person architectural shops, they could theoretically do their whole project in one .dgn file. The file is the 'container' of the project.
(Well I was trying to keep this succinct!) Hope this helps.
