Bentley Communities
Site
Search
User
Site
Search
User
Product Communities
Building
OpenBuildings | AECOsim | Speedikon
Cancel
OpenBuildings | AECOsim | Speedikon | Forum
Slab Opening
State
Suggested Answer
Replies
Answers
1 answer
Subscribers
92 subscribers
Views
Users
0 members are here
Slab Opening
Offline
xonaj31
over 7 years ago
Can anyone help me on how to put an opening on my concrete roof slab with irregular shape.
First i did is to make the profile and then use the creeate complex shape after
I used Place floor slab - shape to put the thickness.
I attached my drawing of the slab.
Thanks.
7380.SLAB PROFILE.dgn
0
Offline
Phil Chouinard
Sat, Nov 7 2015 2:51 PM
Could you identify the product and version you are using?
Cancel
Vote Up
0
Vote Down
Sign in to reply
Verify Answer
Cancel
0
Offline
Phil Chouinard
Sun, Nov 8 2015 4:18 AM
Cancel
Vote Up
0
Vote Down
Sign in to reply
Verify Answer
Cancel
0
Offline
xonaj31
Sun, Nov 8 2015 7:28 PM
in reply to
Phil Chouinard
Hi Phil,
Im using Aecosim Building Designer V8i SS5 Version 08.11.09.747
Cancel
Vote Up
0
Vote Down
Sign in to reply
Verify Answer
Cancel
0
mark.wilhelmsen
Mon, Nov 9 2015 3:02 PM
in reply to
xonaj31
I see two slabs in your model but no profile to create the opening.
First draw the profile that represents the opening. This must be a closed shape or completely extend beyond the edge of the slab.
To cut an opening in a slab, you need to use Cut Solids by Curves (R4 in the Architectural Design Tasks).
Select the slab first, then the profile.
If you want to completely cut through the slab make sure your 'cut mode' is set to through. Otherwise use Define Depth and define the Cut Depth.
Left click to accept.
Cancel
Vote Up
0
Vote Down
Sign in to reply
Verify Answer
Cancel
0
Offline
xonaj31
Mon, Nov 9 2015 5:24 PM
Can anyone help on how to put an opening on my concrete roof slab with irregular shape.
SLAB PROFILE.dgn
Cancel
Vote Up
0
Vote Down
Sign in to reply
Verify Answer
Cancel
