I am drawing a hand balustrade and our legislation needs increase the height of the balustrade at landings.
The height at the pitch of the stair needs to be 900 but at landings it needs to be either 1000-1100mm. Is there a setting to make this possible?
Michael, There is no setting for that at all! AECOsim is not that intelligent and/or flexible at all. You will need to do that manually using MicroStation tools.
Hello Michael,
What version are you using?
New in SELECTseries 6 are the profile tools. The Place Profile tool allows you to extrude a cell from a library along a path (either a path that you draw at placement time or along an existing element) and report on its length and volume.
And these tools can be used for modifying profiles: Ungroup Profle, Break Wall and Connect Forms as (L Bisector)
And they are DataGroup components so you can change the profile with the Modify DataGroup Properties tool.
Hi Paul,
Tried what you suggested, a bit clunky in my opinion, basically you are still using MicroStation tools. Only difference that now you extrude a cell. Getting the impression that AECOsim has been developed by developers and not by designers (no logic in the software). I am adding a video to show how quick and easy it can be.
HTH,
Hiya - we are limited to Select Series 5 due to Client requirements (limitations?).
I have been working with AecoSIM for a (relatively) very short time but to be honest I am finding this a big chore, its not the modelling which is a problem but more the process we need to go through to create drawings such as.
As a company we are trying to arrange for Bentley to come in and give some training to see how you guys are intending all this to work but arranging a date is like pulling teeth.
Apologies for the rant. . . . but when I compare this to learning other software platforms in 12 weeks I managed to learn the new software platform, draw a whole 80m x 25m building grade 2 listed building and get out a set of planning drawings. There also seem to be much more 'fan' based content on the web for other platforms - user buy in for AecoSIM appears limited to the Bentley forums.
*sigh* Not really sure if this helps but it made me feel better! ;-) #Friday #RollOnTheWeekend
Hi Michael,
I have asked a sales colleague to look into your comment on arranging training.
Marc
