New Walls Types in BA
I can't seem to find this anywhere, but just how are new wall types created in BA?
 David William Edwards
  • Hi David,
    Are you referring to creating a new wall type from the Part pull down? If so do this: 1. Pick an existing wall type in the Part pull down. 2. While the Part pull down has focus, click the Space bar on your keyboard, the Dataset Explorer will open. This is where you create new parts. You can also click the TriForma pull down and select Dataset->Parts to open the Dataset Explorer.
    Are you referring to something else?
    Dan
  • No, that was it. I'm trying to learn this without any formal training and at times the Help file doesn't use "standard" expressions for common tasks (e.g. you create "new wall types" by using the "Dataset Explorer"). A task based Help system would be preferred (i.e. "How do I...?")
