Cannot choose Structural XML file in AECOsim
        Good afternoon,
        I have to model a Double-Tee slab in Aecosim, hence i understood i have to open and edit some XML files in Workspace/BuildingDatasets/Dataset_NM/Data/xxxx. xml. I did this in the Excel, exported as a new XML, but i am unable to load this specific XML into Aecosim. There are many different structural xml files here, and i do not find from where to change the path to the edited file.
      Thank you for your help.
      Dan Stroescu
