In a metric workspace, when I place a linear slot diffuser, I find the length (actually called "width") width (actually called "depth") are limited to a number (2540) above which the dialog won't accept... Similarly for "connection length" for which the limit appears to be 152.40, border width 508 etc... Is there anyway to fix this (seems like it comes from imperial units as 1 inch = 25.4 all those limits are multiples of...) SS5 v 747
Chris, I took a look at this and you are correct as we can represent the "installed" length of the overall LSD, so even though the individual parts may be no longer than around 8 foot they may be married together to create longer runs in an installed application. We have created Defect 342350 for this and the limitation will be removed in upcoming releases.
