I have a problem , I model structure and do the drawing at drawing composition I go elevation plan the dimension and elevation automatically shown which I want, but I want to show also labeling of the structural members. I go to the elevation model callout and find option to turn on process label but when I will going back to my sheet the drawing is not updating. In short anything I will do in the elevation model such as turning off grid line and etc. when go back to my sheet the drawing in the sheet is not updated. I try to do reload in the reference file still not.
Simple Frame.dgnHi steve,
Im newly in aecosim, i dont completely understand what your are trying to say. please check the file. In the first picture the dimension and elevation automatically created by aecosim, but I also want to show member names, that is why I go to drawing model to click the check box for "process label" which is in the second picture. but when i come back to my sheet, the sheet drawing doesn't update, still there is no column name label.
Interesting... as long as I check the Process Label option - it was un-checked when I opened the file - the Model Annotation does display as expected in the sheet.
However, I would recommend using a Drawing Rule instead to automatically generate those labels within the Drawing Model itself instead of processing the Model Annotation through the Drawing View. It should still work either way, but Drawing Rule based annotation is much more common and can be moved or otherwise manipulated since it exists in the Drawing Model, unlike Model Annotation which is resymbolized along with the 3D geometry.
Answer Verified By: IronMaxSteel
thanks steve, I dont know how did you make it, but mine really doesnt updated in my sheet. But I agree with you better to do in drawing rules in the drawing manager. I just not give it a try using dynamic view because they say its now the future way to make drawings, but for me still best to generate drawing in the drawing rules.
