Hello Bentleys!
We are trying to set up a Pset called the BIP standard and would like to have some parameters grouped under the customized tab BIP.
We managed to put in some parameters ( ID, typID, etc....) trough "IFC_Mapping_overrides.set" but we also need to put in the actually floor level on every object and in the same tab ( BIP) on the exported IFC.
regards / Oskar
Hello Steve
I would like to get the floor names as marked in yellow, to match the objects.
Like -- all the doors in reference 1 will have "floor 59" attached to it as a parameter
and all doors in the last reference will have "floor 30" attached to it as a parameter.
/Oskar
Hi Oskar,
having set up your building's floors in Floor Manger:
You should then be able to pick the correct floors (if the best fit is not correct) for each reference, the nested references to each floor will follow the master, so in this example I have a three storey building, each floor has two or three models referenced to it.
In the resulting export the objects contain the floor name:
Does this answer the requirement?
Marc
Hello
Thank you for your interest in this matter. We want the floor level to go in our Pset called BIP.
Its a new sweidish standard coming up.
Please se attached img.
/ Oskar
