Hi All,
We've just rolled out SS6 and I've noticed that the ANZ dataset doesn't have New Zealand rolled steel purlins.
I took a copy of the NZ_Fletcher.xml opened it using the StructuralShapesTemplate.xls and added the relevant sections under the "stiffened channel" tab.
When i restarted SS6 the new sections I added to the xml file where avaliable, but now when i go to place any section they come in about 10 times larger then standard.
I've tried making a new file just for the stiffened channels and still have the same problem.
Not sure what i've done/doing wrong but any help would be greatly appreciated
Dave Jones
New Zealand
Marc
Here is the file. I copied the format that was in the AU_Onesteel.xml dataset which works fine
NZ_Dimond.xml
