HI!
When I draw a cable tray in ABD, I can only select the cable tray type and size but there is no such option like the purpose of cable tray i.e. for telecommunication or for ELV services etc.Can anyone help me,how to set desire services?
If you're using the same property values for all cable tray of a certain type, you could define those values in the DataGroup Catalog Editor:
Or, you can also use the Modify Instance Data tool to add those values after placement, which will work with a selection set:
I have found Data Group catalog editor but Cable Tray & other electrical options are not available in catalog Items.How can I add this into catalog item?Please see the snap.
Ah... I did not realize you were running ABD Ss5. In that case your DataGroup catalog for Electrical will not include the individual items I've shown which were added in Ss6. Instead, there should be a single "BBES Element" under the "Electrical" Catalog Type:
However, I noticed in your screen capture that there's a BBESData entry that I don't believe is included by default.
