XML Parts definitions in the UK Dataset reference incorrect Levels - all of them with "M_ " instead of "M-"... Easy fix in text editor but I wonder if anyone else has noted this?
Marc
Hi Marc, I mean that the SS5 levels in the GB Dataset were labeled "M-G524-M-Ventilation" and they are now "M-G524-M_Ventilation". Which is a kind of headache because all cells, annotation cells, parts etc created in SS5 for a company dataset based on GB Dataset need to be modified to account for this change - IF we want all levels to reflect library levels... Any suggestions? I have done the parts xmls fairly easily by editing said xmls and doing a replace in text edition. But for cells, I do not know of any easy way to convert them... Is there?
While on the subject of levels, the UK Dataset design seed files seem to load a copy of all the architectural levels over and above the library levels. Deleting them and updating the levels works temporarily, but on re-opening they do reappear. I have no idea why.
Cheers.
