I am using ABD (select series 4), while I am doing sanitary model I need Short & Long Sweep but there is no such type of fitting in Data set. Is this any other way to solve problem. Kindly suggest me.
Hi Devesh,
You can modify the part parameters in the DataGroup Instance Data dialog when you place them and also modify the parameters of existing parts, see the example below where I have modified the radius from its original value of 25mm to 55mm.
Marc
Answer Verified By: Devesh Kulpehra
