That way, I can generate a surface AECOsim SS6, using the extension of Generative Components, using the node "data importer"? I need to create different surface for distints type users, for example, one mining camp, having different users (manager, workers, etc) But i don't know who types of files read.}
XML is reading but in what way are created and as referenced? any example please ?
Marc
Yes, it's not entirely clear what you need to achieve or the type of surfaces you are starting out with.
But I wonder if perhaps the Promote Element tool is also worth considering?
The Data Import node is typically used for pure data; e.g., database/text format.
