We, Bentley, have been working on compiling an ABD dataset compatible with Uniclass 2015 for some time. The recent changes to the tables has provided an opportunity to carry out a sanity check and ask you users of ABD etc. for your opinion about this standard and how you would want to see it implemented within ABD.
We are particularly interested in your views about how to set up a layering system, what information you would expect to see predefined in the dataset and what you would expect to set your self. Please remember we also have to consider the relevant standards for CAD levels, object naming etc.
Here is a link to the NBS website that has information about the Uniclass Standard.
If possible we would like you feedback as soon as possible, including examples and reasoning.
Many Thanks
Brenden
Hi Brendan,
Uniclass 2015 is still evolving. I hope that Bentley is not only going to provide some 'to-be-completed-by-the-user' xsd defintions to the GB datset and leave it at that. If Bentley are serious about supporting BIM in general and Uniclass in particular, then there should also be some tools and workflows to enable:
1. Bulk updating in future. The schemas and tables are sure to change and evolve.
2. Transforming and merging objects/elements that are imported or simply copied thru from a Ref file. Sure, a lot will be defined at 'project' or 'company' level before a project starts, but inevitably a lot will need to be added as the model develops. I suspect that a lot of users will be adding to the Catalogs by importing objects either by downloading IFC objects or using the RFA Interpreter (maybe we need an IFC-I as well?) or simply copying objects/elements through from a Ref attachment. The embeded IFC, Uniclass, NRM etc information will need to be added into the project schema. i-model Transfomer-type rules-based help would be good. See also what AC provides. Maybe the Aecosim dataset team should use D++ to manage and update datasets in a smart KBE-like fashion. As mentioned above Uniclass and IFC etc are moving targets.
There should be a way to embed the object's xsd information in the object on export / import. Aecosim should be able to re-create the xsd's for any object that is imported.
3. Tools to help the user better visualise and filter the tree structure of the Uniclass (and IFC) schema.
4. Tools to allow the properties and attributes to be cascaded / inherited / derived / managed from over-arching classes.
5. The tools need to be able to deal with nested object/elements.
6. Looking at the Uniclass table links, the Uniclass code comprises Group-Sub group-Section-Object numbers as well as a Title. As a minimum, Aecosim should be able to read these tables and provide drop-down lists, and highlight any inconsistencies. Please do not leave this to the user or CAD admin guy to fill in manually.
7. Uniclass is planned to replace CAWS for specifications and it will be key to be able to cross-check or generate spec clauses from the Uniclass data inputed into the model. The Uniclass data will also have a role for quantity take offs.
Some of the competition has been quite bullish about providing tools to help support the 'I' in BIM. What I think is emerging is a realisation that this needs to be provided in terms of IFC and other industry classification schemas like Uniclass, not just random or vendor-specific parametrics-based info. I think that AC will only get more sophisticated now that Solibri is now in the fold. Aecosim has a lot of fundamental advantages over AC: direct referencing of diverse formats like DWG, IFC, pointclouds, meshes, JT etc, federated from the start, RFA-I, Hypermodeling fusion of 2d into 3d info, ISM, i-models, Project/Asset-wise, EADOC etc etc which makes it a better platform for aggregating and manipulating BIM data from multiple sources. Plenty of muscle in on the geometry side of things. It would be good to bulk up on the non-graphic, data-centric side of things. Aecosim's historical 'soft typing' and 'everything to-be-managed-manually-by-the-user-manually' bias to non-graphic data is no longer good enough.
I am going to make suggestions a little more basic. But I think foundational.
Create Each assembly ( as that is what a uniclass wall is) with:
MY ASSUMPTION. I should be able to create most buildings without editing any section. All I should have to do is dimension and annotate Drawing View. No hatching, patterning, flashing, "X"ing, NOTHING but annotation and Dimension.
This is beyond JUST uniformat, but without a big picture we end up with incomplete pieces. Take Framebuilding, PCS, CCells and what do you have? 3 incomplete products and a poor representation of a door or window library.
Ustn since 1988SS4 - i7-3.45Ghz-16 Gb-250/1Tb/1Tb-Win8.1-64bEric D. MilbergerArchitect + Master Planner + BIMSenior Master Planner NASA - Marshall Space Flight CenterThe Milberger Architectural Group, llc
Dominic and Eric, thanks you for your lengthy replies. I will need to pass most of these onto the developers for future consideration as they involve changes to the application before they can be implemented in any dataset. I do however need to draw Everyone back to the original question. Given the nature of the Uniclass 2015 system what are everyone thoughts about the organisational structure of the Level system we need to create. After all the 1192 standards required in the UK., specifies levels named in the format Discipline_classification_presentation-Description Do we try to use a single table? Do we need to use multiple tables? Will we use different tables during different phases of design e.g.( elements mainly during conceptual design being superseded by systems thereafter) Brenden
Brenden Roche
Applications Engineer
Bentley Systems, Manchester UK
