I wanted to download ABD and went to bentley.com.
And i can't find download?
Where is it?
Hello Thomas,
I've moved your question to the Building Design Forum.
From Bentley.com, click "Support" at the very top > Go To Personal Portal, then click the Software Downloads button at the bottom. This will take you to the Fulfillment Center. Once there, starting typing "aecosim" in the search box, then click AecoSim Building Designer.
Note that you'll need download permissions on your Bentley account in order to download. If you do not have download permissions or are unsure, contact your company's designated Bentley Site Administrator (typically in your IT/Helpdesk department).
regards / Thomas Voghera
You can navigate to connect.bentley.com to go directly to the personal portal. Click "software Downloads" to open the Fulfillment Center. The Fulfillment Center provides access to download your Bentley products. See screenshots below.
