Building Designer Restricting Changes
I'm using Power Inroads to create an excavation model and I've referenced in the structural model and want to simply copy in the mud mat solid then use the graphics as my excavation limits. when I try to copy it into my Inroads file I get the message "Building Designer has intentionally restricted changes to this element". I now have to trace over the mud mat and crate more work for me. Is there a way to unlock this feature? I realize that it's related to BIM and was created by Triforma but this is a real bottle neck for production. Is there a way in Triforma to NOT place BIM elements with this lock on them? I've even written an MDL to try to strip the attributes of the element but it even says the same message that the element cannot be modified. Again is there a way to allow these element to be manipulated in a production drawing using plain Microstation of Inroads. Thanks
