It's possible with AECOSIM get the same output that is done with the Speedikon filters?
Bentley speedikon Architectural includes unique view filter technology, a fully customizable functionality that controls not only level/layer and drawing symbology (color, line weight and style), but also the re-symbolization of 3D objects to 2D symbols. Therefore, from the same building information model, a variety of floor plans, sections, elevations, and details can be generated at different scale and depth of detail, such as design layouts, working drawings, details, orientation or escape route drawings, simply by changing view filters. Because all drawing originate from the same source, consistency and accuracy across all drawings is guaranteed.
Hi Arturo, I believe this is essentially a form of LOD (Level Of Detail). If so, I'm not aware of any ABD built-in functionality that would provide the same results without manual intervention. Question: Does anyone here do this type of thing in ABD today, and if so, how do you go about it?
View online
If you encounter issues clicking "View online", check here.
You received this notification because you are subscribed to the forum. To unsubscribe from only this thread, go here. To unsubscribe from a forum, please see this note.
Flag this post as spam/abuse.
Unknown said:functionality that controls not only level/layer and drawing symbology (color, line weight and style), but also the re-symbolization of 3D objects to 2D symbols. Therefore, from the same building information model, a variety of floor plans, sections, elevations, and details can be generated at different scale and depth of detail
Other BIM systems/users do not suffer from the standard advice/belief that 2D !:2, 1:5, 1:10 etc details are still, pragmatically/realistically, done manually, at best 'tracing over' 1:50 schematic-level sections which are all that the BIM is capable of. Othe BIM systems/users go all-out for the SBM (Single Building Model) ideal.
Which does not mean modelling everything everywhere in total detail;
but models in detail only where detail cuts are to be made,
and automates the various LOD processes by various means - Bentley's own Speedikon has one example of that.
