AECOsim Building Designer Version 08.11.09.863 SS6
When I delete a newly created wall, other unconnected walls are also deleted. There does not seem to be any connection between these created geometries.
I'm very worried because I don't understand what is causing this or how to fix it. I have tried to start a new file and copy the geometry from the old file into the new, the weird connection between walls is still there. Help?
AECOsim Building Designer V8i (SS6) 08.11.09.866
