Hi, I need help with some difficulties I am facing with AECOsim. The main ones are:
1- How can I place arc shape-like of door top-light or be able to modify the shape of door top-light to my desired shape instead of the default rectangular top-light?
2- How can I place triple panel (bay) window? I have tried modifying the parameters (property & value) of 'Place Window Tool' while and after placing a window with no success of getting my desired triple vertical panel window.
Thanks.
The process for a toilet or actually most anything is very simple and very rewarding.
Doors, Windows, Urinals, Toilets, Sinks, ADA H.C Fixture Layouts, furniture, .....etc. They are all the same
I start with a dgn file that I can hold all models of a type like "PLUMBING"
That is where I keep the original I use.
I set up a grid so that everything is at ground zero and has an easy location for the origin
I have in this example anything related to plumbing. The green and red lines are for organization and where they meet is where I would put an origin point
Each have a Plan, A 3d Model and any related annotation I might want to show in 2d beyond the plan and elevations created.
Proper levels, heights and even handles or fixtures, anything I might measure when annotating a drawing, etc.
A toilet here will create a very simple plan or elevation. Even a skewed elevation as it comes from the simple model.I am even trying text that will orientate itself to the view so that things like H (Handicap), C(Child) ext can be placed automatically
As with the standard ADA placement I have some compound models that do more than one fixture. This one is particularly useful as it helps me design the space.
And now as I need models I will start a new compound library. And add models I can use over and over. All the M2.....bxc files are ones I am growing
Right now - for me the dataset does nothing of benefit. I don't provide schedules or any dataset BIM on these elements.
Only doors and windows could benefit from the dataset, however - PCS is too cumbersome to create some of my doors.
I have here the same for a large residence. door, windows, garage doors that I could never create in PCS. And I did try.
PCS is geared toward very simple dumb cells. They don't render well and are very difficult to build and modify.
I did create a couple like the white door in the bottom center. One stopped working and would crash the system. It took days to build and had to be torn down bit by bit and then rebuilt. Very cumbersome and awkward.
I could build these as quickly as I draw. I know the parametrics are not there but they don't really need to be. If I had Connect with parametrics I might use it on the frame and them build it with tools I have off the frame. PCS does not do this well.
MISSING, I KNOW IS THE DATASET FOR SCHEDULES.
Right now I can create the schedules for any project up to 200 doors and windows quicker than PCS as PCS schedules are slow, and don't always work. And the numbering on the drawings is a scary failure as it invites a problem or change order.
I don't consider this a workaround as it seems to be a logical step toward a constrained model using Compound Cells (CCells) and Parametrics from Connect.
Then you CHOSE whether your model will be constrained or something like a toilet that does not need this.
ONE TOOL, FOR ALL CELLS WHETHER SMART LIKE A DOOR OR SIMPLE LIKE A SINK.
Ustn since 1988SS4 - i7-3.45Ghz-16 Gb-250/1Tb/1Tb-Win8.1-64bEric D. MilbergerArchitect + Master Planner + BIMSenior Master Planner NASA - Marshall Space Flight CenterThe Milberger Architectural Group, llc
