Dear All,
I am new to AECOsim Building Designer SS6, I am facing the same problem which was faced by two other users who posted and got the solution for it.
But in my case, changing text size to even unreadable didn't help. I can't select any floor using floor selector. Already gone through two threads available in this forum and tried everything possible. Please help.
Kaushal Aggarwal
Kaushal,
Click on the Floor Selector icon, which can be seen on the left hand side where it says None, and choose the Floor you want to make active and click on the Set Active button.
HTH
Hi Kaushal,
I see you are in SELECTseries 6.
The Floor Selector window changed in SELECTseries 6.
I'm wondering if the project was set up in an earlier version. If so the project's floor master dgnlib needs to have a DataGroup upgrade applied to it..
Here is an "Under the Bonnet" wiki article that explains the procedure.
See if that helps.
Dear Member, I am aware of this option but like to tell you that it was only available in SS5 but as Pual said in his post the floor selector window has been changed in SS6, the problem remains the same.
