I am unclear on what the floor manager is supposed to do
I am told with Revit when MEP services are modelled they can be automatically annotated and dimensioned
Does the floor manager enable automatic labelling of duct/pipe levels and dimensions off grids?
If that is its purpose is there a guide or example avaliable
i have been working on a number of large projects using the Bentley mechanical software and they were all manually dimensioned and had manually edited level cells
Marc
Ustn since 1988SS4 - i7-3.45Ghz-16 Gb-250/1Tb/1Tb-Win8.1-64bEric D. MilbergerArchitect + Master Planner + BIMSenior Master Planner NASA - Marshall Space Flight CenterThe Milberger Architectural Group, llc
currently, with ABD connect edition update 2, there is no way to do this same thing. I can't find a right argument for an archutecture client that need this type of flexibility into his daily work, to recomend AECOSIM over Revit.
