Can anyone explain the easiest way (step by step) to create the curved base slab in aecosim (see plan and section below)? This is the curved base slab of a pumping station. All dimensions are in millimeters.
Windows 10 pro
OpenBuildings Designer Connect Edition 2023 | 23.00.00.114
