When I define a Catalog Item in the ALUMINUM COLUMN or ALUMINUM BEAM Catalog Type, which tool are they supposed to show up?
The closest I can think of is Steel Column and Beam, but they're not there...
Windows 10 pro
OpenBuildings Designer Connect Edition 2023 | 23.00.00.114
Have a look here how Revit does it.
You have to admit that AECOsim is a NOT USER FRIENDLY & CUMBERSOME program! This is so called BIM right?
