OK - I am trying very had to give into they new way of drawing with DG Walls
I realize that my dimensions will be hard to work as now I will no longer dimension from one side of a wall to another and have it read 4', it will now read 3'-10 3/4", which the subs will love dealing with.
But the problem is they don't clean up right. I am now taking 6 extra steps for every joint between two walls.
This is the wall when I tell to extend
I now have to play with the gypsum board to get them to extend properly and to then be cut out where it would not disappear
Is is designed to do this to every joint I create?
Ustn since 1988SS4 - i7-3.45Ghz-16 Gb-250/1Tb/1Tb-Win8.1-64bEric D. MilbergerArchitect + Master Planner + BIMSenior Master Planner NASA - Marshall Space Flight CenterThe Milberger Architectural Group, llc
I don't seem to have either of those in the delivered US dataset, so I used two that seemed to be somewhat close; "Stud MTL-3 5/8 | Brick:4+Sheathing:1/2+ll+Gyp:5/8__9 3/4in" and "Stud MTL-8 | NR__5/8+ll__8 5/8in". I positioned them similar to your image then used the Connect Forms as T tool:
