AECOsim Building Designer V8i (SS 6) Version 08.11.09.863
Is there a guide to creating RCP drawings with AECOsim?
Should the View section cut be above the ceiling pointing down?
Are ceiling types generally differentiated with separate hatch patterns (which I assume requires a separate Level for each hatch)?
How can a grid ceiling that has become disassociated, be reassociated?
Ben,
Go to Drawing Composition and place a Plan Callout, select the option for RCP from Drawing Seed.
HTH
Ustn since 1988SS4 - i7-3.45Ghz-16 Gb-250/1Tb/1Tb-Win8.1-64bEric D. MilbergerArchitect + Master Planner + BIMSenior Master Planner NASA - Marshall Space Flight CenterThe Milberger Architectural Group, llc
Is there a guide to creating RCP drawings with AECOsim? question outstanding, I didn't find this particularly helpful: https://youtu.be/zn4NKt1PVd8
Should the View section cut be above the ceiling pointing down? yes
Are ceiling types generally differentiated with separate hatch patterns (which I assume requires a separate Level for each hatch)? Use Place Grid Ceiling/Finish tool and select type pattern (vs grid and linear).
How can a grid ceiling that has become disassociated, be reassociated - the following answer suggests reassociation not possible.
http://communities.bentley.com/products/building/building_analysis___design/f/5917/t/59387
DOOR SWINGS SHOULD BE VISIBLE IN RCP - HOW IS THIS POSSIBLE?
AECOsim Building Designer V8i (SS6) 08.11.09.866
I know, I am just pointing Ben to the "limited" delivered tools. I don't use AECOsim as my main product, it is not BIM it is CAD.
Answer Verified By: Ben Chapman
