Multiple rules
using aecosim ss6 latest update.
I want to apply multiple rules to 1 object. For example.
Doors have doornumbers and also a RF value. I want to show the numbers and rf values with a symbol. I added annotation cells and created 2 rules. For RF I use a criteria set based on value of datagroups, you can see filled circles for 1H Fire resistance and Half filled circles for 1/2 H fire resistance. I also would like to add the door number with another rule but I do not succeed, only  when putting the rule last (ucb portes) it will add door numbers for all doors that are not in the element selection. is it possible to have multiple rules for 1 item ?  Best regards,
Ronny
