Referencing of DV files
I have created multiple DV files from a model which are then referenced into sheet files. The DV file appears correct in terms of positioning within the DV file itself (when i reference the grid file in) but when i try to reference it into another  file (sheet or design) it does not come in in the correct position. Each floor varies and the figures are random amounts in each case and not the same amount for each floor.
