HI,
I've just started using 3D modeling on AECOsim and using the "clip volume" tool to produce elevations and section.
While most of the level colour and weight can be changed via the level manager but some members don't as show on the picture below:
I can changes its line weight to the orange beam in the picture above in the cut back zone but where it has been cut the member line weight has not be changed,
similar in the C purlins above.
I have a few questions:
Is this a default setting in the programme when some members are to keep there line weight when they are cut through? and can I change this setting? and if so can someone advice me on how to?
If you create your clip volume using the Place Fitted Section, or (preferably) using the Callout tools, the Drawing Seed that you choose in the Tool Settings dialog will apply default view/presentation settings. use of these is one of the topic covered in the product help under "Building Dynamic Views".
We also have a LEARN server course on customizing Building Dynamic Views at Intermediate Workflows for AECOsim Building Designer Learning Path, see the Customizing Dynamic Views to Optimize Drawing Production course on this page.
Marc
Answer Verified By: Marc Thomas
