hej ppl,
I am still quite new to Aecosim with GC extension.
I tried to use GC to place some structural memebers in a grid net generated by GC.
it works fine with horizontal items using ByPoint method, from point A to B. (which means working fine when I am placing a beam)
but its not really working as I wanted if the structural member needs to be place as a column. especially if it needs to be rotated accroding to module net.
please take a look at the attached picture, the dashed red lines are girds, and the column needs to be placed at the intersection, cross section roated correctly along the grids..... but I have checked all the options, I cant use anything like set direction or define coordinatesystem to rotate the cross section. the only way is type in an angel in roatation input..... that is not really what I want....
can anyone give me some hint??
thanks a lot
Leo
hej Steve,
please take a look at the attached file here.
I want the brwon HEA structrucal column to align with the lines (grids) I made....
I can use the rotation for the aligment of the cross section. but I would like to see if I can use any smarter method....
thx
https://communities.bentley.com/cfs-file/__key/communityserver-discussions-components-files/5917/GC_5F00_test.gct
