AECOSIM Dataset Explorer - Hatch Patterns not working
Hi I am using AECOSIM SS6 and I am having issues getting hatch patterns to work from the Dataset explorer.  At the moment I have the default NM dataset but I am also getting the same results from the USM dataset.
I can get the fill, cross hatch and hatch to work, but as soon as I pick a cell for the hatch I get nothing.  I am using this for dynamic views.  The cells are all loaded and if I manually hatch they work fine. (Same Scale and settings)
What am I missing?
Thank you,
John
  • Hi John,
    Just to be sure... after you select the cell, you are changing the pattern type column to Pattern?
  • Yes I am switching to Pattern. I have checked the cells and they work fine for manual hatching. When I switch to cross/Linear hatching they works fine.
  • Interesting... Can you upload one of those XML files here for testing purposes?
  • <?xml version="1.0" encoding="Windows-1252"?>
    <TriForma>
    	<!--Generated By Building Designer, version 08.11.09.255-->
    	<Parts>
    		<PartFamily name="Structural-Existing" version="B1">
    			<Description>Structural Concrete (Beams, Columns,etc.)</Description>
    			<Units master="m" sub="mm"/>
    			<Part name="Conc1">
    				<Description>Existing-Conc1</Description>
    				<Model thickness="0.0000" height="0.0000">
    					<Level>S-E-CONC</Level>
    					<Symbology color="BYLEVEL" style="BYLEVEL" weight="BYLEVEL"/>
    				</Model>
    				<CutView activate="true" cutInCompoundCells="false">
    					<Unifier activate="false">SELF UNIFIER</Unifier>
    				</CutView>
    				<FrontAndRearView activate="true">
    				</FrontAndRearView>
    				<CutPatterns activate="true">
    					<FilledColor activate="false" color="0"/>
    					<Pattern mode="CROSSHATCH">
    						<LinearHatching angle1="-45.000000" spacing1="0.3000">
    							<Symbology color="252" style="BYLEVEL" weight="BYLEVEL"/>
    						</LinearHatching>
    						<CrossHatching angle1="-45.000000" spacing1="0.3000" angle2="45.000000" spacing2="0.3000">
    						</CrossHatching>
    						<Patterning rowSpacing="0.0100" columnSpacing="0.0200">
    							<Cell angle="0.000000" scale="1.000000">ADOBE</Cell>
    						</Patterning>
    					</Pattern>
    				</CutPatterns>
    				<Centerline activate="false">
    					<Level>Default</Level>
    					<Symbology color="0" style="0" weight="0"/>
    					<CustomLine scaleToForm="false" scale="1.000000"/>
    				</Centerline>
    				<Rendering activate="true">
    					<Palette>$(_DGNLIB)|Bentley_Materials.dgnlib|Concrete&amp;Pavers.pal</Palette>
    					<Material>Concrete_8</Material>
    				</Rendering>
    				<Notation>
    					<Dimension type="NONE" side="RIGHT" offset="0.0000"/>
    				</Notation>
    				<Quantification>
    					<CompFormula>
    						<ComponentRef family="Concrete" component="1"/>
    						<Formula>VOL</Formula>
    					</CompFormula>
    				</Quantification>
    				<TriFormaApp>
    					<Structural version="B1">
    						<MemberLine constructionClass="true">
    							<Level>S-SLAB-CONC</Level>
    							<Symbology color="BYLEVEL" style="5" weight="0"/>
    						</MemberLine>
    						<Geometry>
    							<CrossSection sectionName="" showFillets="false"/>
    							<Orientation rotation="0.000000" mirror="false" placementPoint="CENTER_CENTER" localYOffset="0.0000" localZOffset="0.0000"/>
    							<Placement placeBy="TWOPOINTS" length="0.0000"/>
    						</Geometry>
    						<Coping automaticCoping="false" copingType="MEMBER_CONNECTED_BY_ACCUSNAP">
    							<Clearance flangeClearance="0.0000" webClearance="0.0000"/>
    							<Corner cornerType="PLAIN" cornerRadius="0.0000"/>
    						</Coping>
    						<DataLabels>
    							<Data type="FAMILY"/>
    							<Data type="PART"/>
    							<Data type="SECTION_NAME"/>
    							<Data type="MARK"/>
    							<Data type="STATUS"/>
    							<Data type="CLASS"/>
    							<Data type="GRADE" name="4000 psi"/>
    							<Data type="MATERIAL" name="Concrete"/>
    							<Data type="TYPE"/>
    							<Data type="USER_DEFINED_1"/>
    							<Data type="USER_DEFINED_2"/>
    							<Data type="USER_DEFINED_3"/>
    							<Data type="USER_DEFINED_4"/>
    							<Data type="END_1_ACTION"/>
    							<Data type="END_2_ACTION"/>
    							<Data type="END_1_DETAIL"/>
    							<Data type="END_2_DETAIL"/>
    						</DataLabels>
    						<Analytical>
    							<AnalyticalLine>
    								<Level>S-ANLY-MEMB</Level>
    								<Symbology color="BYLEVEL" style="BYLEVEL" weight="0"/>
    							</AnalyticalLine>
    							<Member prefix="" lowestId="0" increment="0" location="PLACEMENT_POINTS" type="BEAM" rigidOffsets="false"/>
    							<Release>
    								<End1>
    									<Axis x="false" y="false" z="false"/>
    									<Rotation x="false" y="false" z="false"/>
    								</End1>
    								<End2>
    								</End2>
    							</Release>
    						</Analytical>
    					</Structural>
    				</TriFormaApp>
    				<AnalyticalMaterial/>
    			</Part>
    			<Part name="Conc1 Reuse">
    				<Description>Existing-Conc1 Reuse</Description>
    					<Level>S-E-CONC1-REUSE</Level>
    				</Model>
    				</CutView>
    				</FrontAndRearView>
    						</LinearHatching>
    						</CrossHatching>
    						</Patterning>
    					</Pattern>
    				</CutPatterns>
    				</Centerline>
    				</Rendering>
    				<Notation>
    				</Notation>
    				<Quantification>
    					<CompFormula>
    					</CompFormula>
    				</Quantification>
    				<TriFormaApp>
    						</MemberLine>
    						<Geometry>
    						</Geometry>
    						</Coping>
    						<DataLabels>
    							<Data type="PART"/>
    							<Data type="MARK"/>
    							<Data type="TYPE"/>
    						</DataLabels>
    						<Analytical>
    							<AnalyticalLine>
    							</AnalyticalLine>
    							<Release>
    								<End1>
    								</End1>
    								<End2>
    								</End2>
    							</Release>
    						</Analytical>
    					</Structural>
    				</TriFormaApp>
    			</Part>
    		</PartFamily>
    		<PartFamily name="Structural-Proposed" version="B1">
    			<Part name="Conc1">
    				<Description>Conc1</Description>
    					<Level>S-P-CONC1</Level>
    				</Model>
    					<Unifier activate="true">SELF UNIFIER</Unifier>
    				</CutView>
    					<Level>S-P-CONC1_FAR</Level>
    				</FrontAndRearView>
    						<LinearHatching angle1="-45.000000" spacing1="0.2000">
    						</LinearHatching>
    						<CrossHatching angle1="-45.000000" spacing1="0.2000" angle2="45.000000" spacing2="0.2000">
    						</CrossHatching>
    						</Patterning>
    					</Pattern>
    				</CutPatterns>
    				</Centerline>
    				</Rendering>
    				<Notation>
    				</Notation>
    				<Quantification>
    					<CompFormula>
    					</CompFormula>
    				</Quantification>
    				<TriFormaApp>
    						</MemberLine>
    						<Geometry>
    						</Geometry>
    						</Coping>
    						<DataLabels>
    							<Data type="PART"/>
    							<Data type="MARK"/>
    							<Data type="TYPE"/>
    						</DataLabels>
    						<Analytical>
    							<AnalyticalLine>
    							</AnalyticalLine>
    							<Release>
    								<End1>
    								</End1>
    								<End2>
    								</End2>
    							</Release>
    						</Analytical>
    					</Structural>
    				</TriFormaApp>
    			</Part>
    			<Part name="Conc2">
    				<Description>Conc2</Description>
    					<Level>S-P-CONC2</Level>
    				</Model>
    				</CutView>
    					<Level>S-P-CONC2_FAR</Level>
    				</FrontAndRearView>
    						</LinearHatching>
    						</CrossHatching>
    						</Patterning>
    					</Pattern>
    				</CutPatterns>
    				</Centerline>
    				</Rendering>
    				<Notation>
    				</Notation>
    				<Quantification>
    					<CompFormula>
    					</CompFormula>
    				</Quantification>
    				<TriFormaApp>
    						</MemberLine>
    						<Geometry>
    						</Geometry>
    						</Coping>
    						<DataLabels>
    							<Data type="PART"/>
    							<Data type="MARK"/>
    							<Data type="TYPE"/>
    						</DataLabels>
    						<Analytical>
    							<AnalyticalLine>
    							</AnalyticalLine>
    							<Release>
    								<End1>
    								</End1>
    								<End2>
    								</End2>
    							</Release>
    						</Analytical>
    					</Structural>
    				</TriFormaApp>
    			</Part>
    			<Part name="Conc3">
    				<Description>Conc3</Description>
    					<Level>S-P-CONC3</Level>
    				</Model>
    					<Level>S-P-CONC3_FAR</Level>
    				</CutView>
    				</FrontAndRearView>
    						</LinearHatching>
    						</CrossHatching>
    						</Patterning>
    					</Pattern>
    				</CutPatterns>
    				</Centerline>
    				</Rendering>
    				<Notation>
    				</Notation>
    				<Quantification>
    					<CompFormula>
    					</CompFormula>
    				</Quantification>
    				<TriFormaApp>
    						</MemberLine>
    						<Geometry>
    						</Geometry>
    						</Coping>
    						<DataLabels>
    							<Data type="PART"/>
    							<Data type="MARK"/>
    							<Data type="TYPE"/>
    						</DataLabels>
    						<Analytical>
    							<AnalyticalLine>
    							</AnalyticalLine>
    							<Release>
    								<End1>
    								</End1>
    								<End2>
    								</End2>
    							</Release>
    						</Analytical>
    					</Structural>
    				</TriFormaApp>
    			</Part>
    			<Part name="Gating1">
    				<Description>Grating1</Description>
    					<Level>S-P-GRAT1</Level>
    				</Model>
    				</CutView>
    				</FrontAndRearView>
    						<LinearHatching angle1="-45.000000" spacing1="0.0500">
    						</LinearHatching>
    						<CrossHatching angle1="-45.000000" spacing1="0.0500" angle2="45.000000" spacing2="0.0500">
    						</CrossHatching>
    						</Patterning>
    					</Pattern>
    				</CutPatterns>
    				</Centerline>
    				</Rendering>
    				<Notation>
    				</Notation>
    				<Quantification>
    					<CompFormula>
    					</CompFormula>
    				</Quantification>
    				<TriFormaApp>
    						</MemberLine>
    						<Geometry>
    						</Geometry>
    						</Coping>
    						<DataLabels>
    							<Data type="PART"/>
    							<Data type="MARK"/>
    							<Data type="TYPE"/>
    						</DataLabels>
    						<Analytical>
    							<AnalyticalLine>
    							</AnalyticalLine>
    							<Release>
    								<End1>
    								</End1>
    								<End2>
    								</End2>
    							</Release>
    						</Analytical>
    					</Structural>
    				</TriFormaApp>
    			</Part>
    			<Part name="Gating2">
    				<Description>Grating2</Description>
    					<Level>S-P-GRAT2</Level>
    				</Model>
    				</CutView>
    				</FrontAndRearView>
    						</LinearHatching>
    						</CrossHatching>
    						</Patterning>
    					</Pattern>
    				</CutPatterns>
    				</Centerline>
    				</Rendering>
    				<Notation>
    				</Notation>
    				<Quantification>
    					<CompFormula>
    					</CompFormula>
    				</Quantification>
    				<TriFormaApp>
    						</MemberLine>
    						<Geometry>
    						</Geometry>
    						</Coping>
    						<DataLabels>
    							<Data type="PART"/>
    							<Data type="MARK"/>
    							<Data type="TYPE"/>
    						</DataLabels>
    						<Analytical>
    							<AnalyticalLine>
    							</AnalyticalLine>
    							<Release>
    								<End1>
    								</End1>
    								<End2>
    								</End2>
    							</Release>
    						</Analytical>
    					</Structural>
    				</TriFormaApp>
    			</Part>
    		</PartFamily>
    		<PartFamily name="Structural-Removals" version="B1">
    			<Part name="Conc1">
    				<Description>Removals-Conc1</Description>
    					<Level>S-R-CONC1</Level>
    				</Model>
    				</CutView>
    				</FrontAndRearView>
    						</LinearHatching>
    						</CrossHatching>
    						</Patterning>
    					</Pattern>
    				</CutPatterns>
    				</Centerline>
    				</Rendering>
    				<Notation>
    				</Notation>
    				<Quantification>
    					<CompFormula>
    					</CompFormula>
    				</Quantification>
    				<TriFormaApp>
    						</MemberLine>
    						<Geometry>
    						</Geometry>
    						</Coping>
    						<DataLabels>
    							<Data type="PART"/>
    							<Data type="MARK"/>
    							<Data type="TYPE"/>
    						</DataLabels>
    						<Analytical>
    							<AnalyticalLine>
    							</AnalyticalLine>
    							<Release>
    								<End1>
    								</End1>
    								<End2>
    								</End2>
    							</Release>
    						</Analytical>
    					</Structural>
    				</TriFormaApp>
    			</Part>
    			<Part name="Conc2">
    				<Description>Removals-Conc2</Description>
    					<Level>S-R-CONC2</Level>
    				</Model>
    				</CutView>
    				</FrontAndRearView>
    						</LinearHatching>
    						</CrossHatching>
    						</Patterning>
    					</Pattern>
    				</CutPatterns>
    				</Centerline>
    				</Rendering>
    				<Notation>
    				</Notation>
    				<Quantification>
    					<CompFormula>
    					</CompFormula>
    				</Quantification>
    				<TriFormaApp>
    						</MemberLine>
    						<Geometry>
    						</Geometry>
    						</Coping>
    						<DataLabels>
    							<Data type="PART"/>
    							<Data type="MARK"/>
    							<Data type="TYPE"/>
    						</DataLabels>
    						<Analytical>
    							<AnalyticalLine>
    							</AnalyticalLine>
    							<Release>
    								<End1>
    								</End1>
    								<End2>
    								</End2>
    							</Release>
    						</Analytical>
    					</Structural>
    				</TriFormaApp>
    			</Part>
    		</PartFamily>
    	</Parts>
    </TriForma>
    I am having issues with all .xml files custom and out of the box.  They just don't want to use the cell files to hatch.  I am using out of the box .cell files.
    I have included one of my XML files but I think it is a config or software issue.
  • I am having this same problem. I am on the newest version of ABD SS6. I also cannot figure out what or if there is a variable that gets a specific cell pattern library into ABD?
