Hello Good Bentley Community,
Once again I'm in a sticky situation here,
It turns out that I need to make a terrain (Surface or Mesh) using level curves, because I'm working on an academic project (for a good friend) that is located between mountains (lots of mountains where I come from).
Is there a set of tools for terrain modeling in our beloved ABD?
Here's a picture of the project
Best Regards
Rafael
The beloved tools for terrain modeling from Bentely are InRoads, GeoPack, MX :-) With level curves, Do you mean "Contours"?
With Microstaton V8i(SS3+) and Connect Edition we got a "Terrain Model Toolbox" and Terrain Model Elements
And you've got the Mesh tools like
Used to construct a triangulated mesh element from a selected set of contours.
You can access this tool from the following:
(Command: FACET TRIANGULATE CONTOURS)
Frank
Answer Verified By: Steve Cocchi
