Hello
I would like to concatenate ArchSpace/@label and ArchSpace/@label2 on the export to IFC.In IFC_Mapping_overrides i have:
TYPE Space PROPERTY_SET BIP "Area" : "IfcLabel" = ArchSpace/Area/@actualGross "RoomName" : "IfcIdentifier" = ArchSpace/@Label "RoomNumber" : "IfcIdentifier" = ArchSpace/@Number "Storey" : "IfcIdentifier" = ObjectBIP/@StoreyName // "TestMergedRoomName" : "IfcIdentifier" = CONCAT("ArchSpace/@label", ArchSpace/@label2) END_PROPERTY_SET
Do i need to call a function or something? I tried with + and &.
regards / Oskar
Unknown said:I would like to concatenate ArchSpace/@label and ArchSpace/@label2 on the export to IFC.
Oskar,
I use this to Concatenate our space labels. Must be using SS6 (Version 08.11.09.866) or newer...
Following lines are added to IFC_Mapping_overrides...
TYPE Space CLASS_MEMBERS
"LongName" : "IfcText" = EVALUATE DG("ArchSpace/@label") ADD " " ADD DG("ArchSpace/@label2") ADD " " ADD DG(SBS_Space/@Label3)
END_CLASS_MEMBERS
HTHs
Tom
Answer Verified By: Steve Cocchi
Thank you, it works perfect. / Oskar
