HVAC library for aecosim
Hello
We are starting using a mechanical part in our office and we have found a few problems with HVAC cells because some of them looks quite different than in a real life f.g. round dampers, some equipment etc. and it takes a lot of time to modify them. Does anybody know a hvac/plumbing manufacturer who have a library for aecosim? I haven't found any on internet.
I am using SS6
  • As AECOsim Building designer is a Proprietary product, there may not be a Mechanical /Plumbing Supplier who’s parts will resembles Bentleys, as Bentley’s is molded close to “industry Standards” and product standardization as conceivably possible. There are many manufactures of these items and although they are call by the same product name, their configuration and features can vary.
    We recommend that if ther is one particular manufacture / supplier that your office uses over another, we would suggest that you use the RFA interpreter for that manufacture. You than can build a library of mechanical and plumbing components used most often by your office and the add particular product data to each item, and then add them to you new product library.
Reply
