AECOSIM
hello all
I  created a user defined custom section in AECOSim ,  and i followed all the steps correctly . but the problem start when i open the section in AECOSim building designer tool bar , the section is bigger than normal section . i input the dimension in millimeters  user defined section is bigger than normal millimeter  section . please see the pictures.  How to  fix this problem.
Thank you
REI
