I am having problems within projectwise and Aecosim where after introducing updated references, old clip data is still displayed, as if it was cached somewhere. For Example: I have a long section of a tunnel that that has changed in dimension, everything looks fine even in the clip right up until the view is promoted, then an old clip appears and clashes with the new clip.
Hello James,
Please try compressing the files involved turning on the "Delete Building Dataset Elements” and “Delete Building Display Accelerators” options and using the Copress References button. Please see Compress Options in AECOSim Building Designer - Behaviour and Configuration for some background on these options.
Marc
