I used AECOsim to analysis the solar exposure, the weather file is from energyplus.net weather.
I add Taiwan and Vancouver weather file, but the calculator display the same result.
Theoretically, they should be different.
I installed version SS6 "bim081109866en". Is it not a new one?
I try lots of areas, the result is like this picture.
Yes, I change the solar position, but it's a problem I find, when I save the solar file, the setting will back to and reset.
This is my settings.
