Export IFC - Compound Walls
I have a problem when exporting to IFC a file with Compound walls. Let me explain because it is something inexplicable:
- I made this file, that is symmetric type plan. I placed Compound walls for the facades and for some dividing interior walls. I made the left half and when finished I made a mirrored copy (the red rectangle in the plan view). As you can see in the image, when place the cursor over the the facade  it shows "default" as it is a Compound wall.
The problem is that when I export this file to  IFC and open in Solibri, the right  mirrored half shows the Compound walls as single wall layers and each layer named "default", while the original draw part (left half) shows the compound wall as a single wall with its datagroup name ("Fachada ventilada"):
Then, If i delete the original drawn half (left half) and then I make a mirrored copy of the left half to the right, the IFC shows all facades as disggregated single walls named "default", as you can see in the image below:
This is very interesting when you can control it, but when not it is tedious. For example, for a construction model to be used in 4D planning it may be very useful to have single wall layers for every compound wall so you can link every wall layer to its task.
So the question is: Does anybody know how to control that? Why the original compound walls are exported as a single wall and the mirrored walls exported as compound wall withe single layers? Is there any command to control this?
By the way, I'm using ABD Ss6 08.11.09.831
Thank you!
