Add 2D Structural Section profile from xml-files (STRUCTURAL_SHAPES)
Hi, In previous version we used steel.ma for placing 2D Steel Structural Section profiles. Now (ABD SS6) we only use our own xml-files (STRUCTURAL_SHAPES) for Structural profiles (3D). But how on earth is it possible to place a Structural Section profile into a 2D-design from the same xml-database?
I've search the net with no luck. The only what I came across was:
http://communities.bentley.com/products/building/building_analysis___design/f/5917/p/26209/60522 http://communities.bentley.com/communities/other_communities/bentley_library/w/bentley_library__wiki/steel http://communities.bentley.com/products/microstation/w/microstation__wiki/14223.is-there-a-plugin-to-add-2d-steel-structural-section-profiles
