COBie - floors when exporting from AECOsim SS6
When creating COBie spreadsheets from AECOsim our spaces always appear to be attached to the same floor. We have 5 floors in the model and using the floor manager the spaces were created on separate floors.
When exporting to IFC/COBie we have use the assign floors and spaces to move model files to different floors. We receive the same result each time which is that all spaces go onto the same floor.
1. What is the best practise to create spaces on separate floors?
2. What is the best pracise to move a space already assigned to one floor to another floor?
3. Where are the best resources which talk about floor/space creation and COBie in general?
4. Do Bentley provide any example files which export to COBie which can be used effectively as tests. We can then reverse engineer these models to gain a better understanding.
  • Hi Michael,
    The initial word back from development is that in order for components (including spaces) to be separate out by floor in COBie, the elements themselves need to exist in separate Models. If you can, try copying just a few elements from any floor (other than the one currently being exported) into a new DGN file, move them from their original location in that new file (and perhaps modify as well), then reference that new file into the original DGN and re-export to COBie. Do these copied elements show as belonging to expected floor?
Reply
  • Hi Michael,
