Floor Manager does not work if i change the user
Hi Everyone!
I changed default user to new one as ARCHITECTURE-01
went to create to floors in Floor Manager and i got error prompt as below.
I checked continue then try to work but there is no use. finally i opened project with default user, its working. Kindly help me out. I want to work with different users.
Akbar Ali K
  • Floor Manager is defined by the configuration variable BB_FLOORMASTER_DGN.  It is usually defined in the Project so it is possible that when you change the User name that the Project name is also changed and that the Floor Manager file does not exist in the defined location.  You can change to the User, ARCHITECTURE-01, then open Workspace Configuration to BB_FLOORMASTER_DGN and look at where this variable is defined for the current project or re-define the variable to read the location of your BB_FLOORMASTER.dgnlib file.
  • Greetings!
    Thanks Mr. Robert DiMauro, I just did what you said. The prompt error message is not showing when i open floor manager. And i can not found any floors in floor manager, just empty. I try to add floor then another prompt message came. Please let me know what to do next.
    Akbar Ali K
    Akbar Ali K
  • Akbar, did you re-define the location and name of a BB_FLOORMASTER.dgnlib file in your configuration? Does it now point to where the floor manager file resides? Also, to the right of the BB_FLOORMASTER_DGN configuration variable in the dialog box, does it say User or Project?
    Answer Verified By: Akbar Ali
  • Hi
    Thanks Mr Robert, I missed to define BB_FloorMaster.dgnlib file in configuration. Now i changed and its working. Thanks a lot!!!
    Akbar Ali K
  • We are trying to do something similar.
    Using W10 / OBD U5 10.05.00.49
    All of our files are stored on a central server in a by customer by project# hierarchy.  We do not really want to create a separate workspace for every customer nor do we want to create a separate workset for every project.
    I tried to relocate the BB_FLOORMASTER.DGNLIB file to our 3D_MODELS directory in our project directory structure.  Then I reconfigured the following variable accordingly (in our Organization standards.cfg) so that from inside a model in that directory you would be able to attach the floors or grid found in the library in that directory.
    BB_FLOORMASTER_DGN = $(_DGNDIR)/BB_FloorMaster.dgnlib
    SMC_COLUMNGRID_DEFINITION_DGNLIB = $(_DGNDIR)/BB_FloorMaster.dgnlib
    The Grid seems to be working fine, however it will not bring up the floor manager.  we get the "un-handled exception" error above and in the message box it says that the "BB FLOORMASTER POINTS TO AN INVALID FILE"
