I need to create a floor plan with a cut plane at 2 different elevations (approx. 3 feet apart). I know it involves step handles which controls the cut planes. Any info would be very much appreciated. THANKS!
-Raymond
Create a regular clip volume drawing view using the Place Plan Callout around the area of the model where you want an elevation. Then go back and right click on one of the handles of the clip volume. Select 'Create Step'. This will allow you to create a step in the section cut line where you want it to occur and then finish the creation of the section cut.
You might also want to check this forum post showing how to create a step in an existing drawing view.
https://communities.bentley.com/products/building/building_analysis___design/f/5917/t/95803
Answer Verified By: Marc Thomas
