Seems to have been asked a few times in the past but what's the deal with offsetting 3D lines (with varying Z values at vertex points)
If I used the move parallel command (in top view) to offset a line by 750mm it only moves 145mm away from the original line and the accudraw changes from top rotation to an angled one.
There must be a command to offset 3D lines correctly now in ABD SS6? Surely?
Marc
Hi Davulsukur,
Individual segments copy parallel at the same z height, 3d curves or multiple segments are transformed including z, a mode that copies parallel at the same z would presumably be a different kind of transform so would need an enhancment or new feature. You would need to file a Service Request asking for such an enhancement.
It might also be worth checking in the MicroStation Forum to see if anyone there has other suggestions. Copy Parallel is a MicroStation (platform) tool.
How about a custom line style? In the front view below the two copies of the b-spline have been transformed in z, but changing the line style of the original to the (this is quite crude but adequate for demonstation) '{ Rail Road }' line style you can see the parallel rails have the same z-height.
You could create a custom line style at the correct scale and spacing to achieve a similar result, might that do the job?
Answer Verified By: Steve Cocchi
