Workspace template in AECOsim CE
I have created a new workspace in AECOsim Connect Edition.
The _USTN_WORKSPACESTANDSURDIRS variable create the folders.
But the folders are empty.
Is it possible to add dgnlib files or other files to folders when I create a new workspace automatically?
Or after the create the WorkSpace, I have to manually add these files
I will like have a template for create WorkSpace
View image
Thank you
Joaquín
AECOsim 10.00.00.154 en
  • Hi Joaquin,
    Please take a look at the "WorkSet Templates" feature. This is a Technology Preview (installed by default unless deselected during installtion) in the inital ABD CE release available in the Create WorkSet Dialog.
    Out of the box you can use it to select one of the delivered WorkSets as a template, then make any chnages that you need to suit your purposes and use the modified copy and a templete for futuer projects. Unless the 'Create Folders Only' box is ticked all files containing in the source WorkSet will be copied to the new WorkSet. This will include any designs as well as WorkSet level dataset files so any template workset used for production will need to be cleaned up.
    This feature may develop further as it moves to a released feature.
    We would welcome any feedback on this feature to inform future development.
    Marc
  • Hi Marc,
    I asked for workspace not for the workset
    Maybe a better Workspace template option and not use the variable _USTN_WORKSPACESTANDSURDIRS
    Thank you
    Joaquín
