Hello, I placed a windows in the wall.
The window is a PAZ file.
I edit the PAZ file and also I modify this file in the PCS program.
I has select save and return but in AECOsim the window not is modifyed
The same with other PAZ files (louvers, curtainwalls, etc.)
Why?
How can I solve it?
Joaquin
AECOsim CE 10.00.00.154 Dataset_USWindows 7 64 bit spanish version
Agree with you !
But FWIW, the Modify tool does work on multiple doors. Not sure if you noticed.
Same issue with editing parametrics of PAZ file (can't edit louvers)..
Guys it's already 2021, and we still have the same issue after 4 years of application updates..?
OpenBuilding Designer CE 10.0.8.44 Dataset_NM
