Hello, in the section plan of the stair appears a line green in the axis.
How to change the color of the line green of the symbol of the stair?
This occurs in Aecosim CE. See image
Thank you
Joaquín
AECOsim 10.00.00.154 Dataset_US
We can change the Display Setting options in Clip Volume Setting to alter color of entire stair geometry including center line, however will investigate if specific change of center line color possible.
Answer Verified By: Joaquin
Hello Aniruddh,
Ok, now I see that with the display styles and display rules in Connect Edition also it can help.
Thanks for your help.
